CM 4.1.3 MOH doesn't work
in the Event Viewer I can see the following message:
The call to start a TFTP download request failed.
On the phone I hear only 3 Beeb.
The audiofiles ar under MOH in TFTP Directory.
Thanks David
1 REPLY
Silver
Re: CM 4.1.3 MOH doesn't work
The error seems to be just cosmetic. Do you have your MOH server assigned to MRG->MRGL->Device Pool ?
If you are using g.729 codec for this call you would need to enable g.729 MOH support in IP Voice Media Streamin App service parameters
CSCeg56360 Bug Details
Headline IPVMSAPP Service Logs Errors about Download Failure of MOH Files
First Found-in Version 4.0(2a)
First Fixed-in Version 4.2(0.368)
Release Notes
Symptom:
A error message similar to below is logged on the CM Application Log.
Event Type: Error
Event Source: Cisco IP Voice Media Streaming App
Event Category: None
Event ID: 3
Date: 12/16/2004
Time: 8:14:38 AM
User: N/A
Computer:
Description:
Error: kDownloadMOHFileFailed - Download request failure.
File Name: SampleAudioSource.ULAW.wav
App ID: Cisco IP Voice Media Streaming App
Cluster ID: -Cluster
Node ID:
Explanation: The TFTP download request failed.
Recommended Action: Validate the TFTP IP address in the database and that the
file exists..
Conditions:
The above Error is generated during the bootup of the Server.
Workaround:
None. This seems to be just a cosmetic Error message
130
