CM 4.1(3): No Calling Name using QSIG?
Hi all,
we are using a gateway (using qsig) to connect to a BOSCH 33XE PBX.
Everything works fine, only names from callmanager are not shown at the PBX phones, while PBX-user names are shown at the IP phones.
I did a "debug isdn q931" to have a look and I saw a calling number, but no calling name (calling from callmanager to PBX).
Any ideas?
Axel
p.s. I checked the route pattern and the gateway setting belonging calling name restriction: nothing.
Green
Re: CM 4.1(3): No Calling Name using QSIG?
Hi Axel,
Which Q.SIG variant you are using to connect to the PBX? 0x9F (ISO) or 0x91 (ECMA)
In Cisco CallManager you may want to check those values under:
CCMAdmin | Service | Service Parameters | Cisco CallManager | Click Advanced
ASN.1 ROSE OID Encoding*
QSIG Variant*
You may want to match these parameters to your PBX.
I tried both variants (but read, that calling name is part of qsig basic) with same result.
Here is a part of the debug:
4w1d: Modify Nominator =
4w1d: DTMF_TONE_DET
4w1d: MODEM
4w1d: CODEC_BYTES
4w1d: NTE_PAYLOAD
4w1d: DTMF_RELAY
4w1d: NSE_PAYLOAD
4w1d: SIGNAL_TYPE
4w1d: FAX_BYTES
4w1d: NTE_TX_PAYLOAD
4w1d: SEQ_NUM_START
4w1d: MP_CAP_MODEM_PROTO
4w1d: MP_CAP_MODEM_CODEC
4w1d: MP_CAP_VOICE_RTP_NSE_PAYLOAD
4w1d: MR_INFO
4w1d: FAX_TONE_DET
4w1d: MODEM_TONE_DET
4w1d: CM_TONE_DET
4w1d: ISDN Se0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0041
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Facility i = 0x91AA06800100820100A11602010106042B0C0900800B542E20536368756C756E67
Calling Party Number i = 0x0081, '8834999'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '8'
Kind regards
Axel
Green
Hi Axel,
Per the last debug 0x91 in CCM, you are using ECMA variant, make sure that under CCM Service Parameters ASN.1 ROSE OID Encoding* is set to ECMA also, those values should match in the PBX side.
If that is the case, please upload the detailed CCM trace.
//G
Hi //G,
thanks for you help. It is a productive system, so I am not able to post ccm traces here.
I will open a Service Request.
Kind regards
Axel
Transform this Hex string:
to ASCII (e.g. http://www.yellowpipe.com/yis/tools/encrypter/index.php)
and you receive the send displayname.
Axel
201
