CM + IPAA - no ringtone HELP!
I am running CM + IPAA but for some reason when a user enters a person's extension and it transfers to that extension, there is no ring tone on the caller's end. The extension that is being transferred to does ring so the person on the line doesn't know what's going on. Please help!!
1 REPLY
Re: CM + IPAA - no ringtone HELP!
How about transfer from one ip phone to another do you have the samer problem if you attempt a blind transfer. If yes you have to add the following commands on the H323 gateway through which the call is comming. on the voip dial peer progress_ind setup enable 3
103
