CM joins domain, DC Directory will not start
When a CM 3.2(2c) is joined to a domain (is currently a workgroup member) and reloaded, the DC Directory service will not start, however the CM continues to function ok. The only resolution at this time is to revert to a backup disk.
Bronze
Re: CM joins domain, DC Directory will not start
what do you mean "reloaded"? rebooted? Are you also using the AD connector?
geoff
sorry, I was a bit vague. When the CM is joined to the domain, it says it has to be rebooted. The the CM has restarted, the DC directory reports an error in the event log stating that the directory was shutdown abnormally without journalling enabled, and that it should be restored from a backup.
The CM does not have the AD connector installed.
84
