CME 3.4 and Idle URL -- XML authoring documentation
I would like to create a simple idle URL that would basically display a changing text message similar to the "system message" option in CME, as well as the local weather conditions. We have a mix of 7940, 7960, and 7970 IP phones.
Is there a document that explains how to author the XML for the idle URL feature? I need to know the file structure the phone will be expecting, what tags are supported and which are not, etc.
Chris
Re: CME 3.4 and Idle URL -- XML authoring documentation
I'd refer to the Ip Phone services development guide: http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_programming_usage_guide_book09186a00806eb3ea.html
I'm unaware of any unsupported tags, other than those that your non colored phones won't support (the document I linked to has a list which device supports which kind of tags).
Thanks! I'll start going though that!
178
