Community Member
CME 4.0 Problem with TSP
I´m running CME 4.0.
When we install the shipped TSP-Client on a PC and do everything as we were used to with former CME-Versions like username and password to assosiate a secific line we can monitor incoming calls without any problems but we are not able to control the phone-line for outgoing calls.
The configuration of this TSP-Client is different to the former Versions regarding the line-configuration because you can configure several lines with different functions (e.g. line appearances, cfb etc.). Because of this I´ve configured Line 1 as DCA (Dual Call Appearance).
It is not possible to select e.g. in Windows-Dialer a specific line of the TSP-Client but you can only select the "Cisco CME Telephony Service Provider" without specific line.
Did I forget something to configure, has anybody a similar expirience or is this a known bug?
Thanks for any idea.
Re: CME 4.0 Problem with TSP
Cisco Unified CME TSP 2.0 Components
Cisco Unified CME TSP 2.0 requires the following software:
Cisco Unified CallManager Express:
Cisco Unified CME 3.3 with Cisco IOS release 12.4
Cisco Unified CME 4.0 with Cisco IOS release 12.4(4)XC or later
Microsoft Windows 2000 or Windows XP
A compatible TAPI application, like Microsoft Outlook, to utilize the TAPI driver
Community Member
thanks for your information.
I found out that MS Office Outlook XP and 2003 works properly.
It seems that there are problems with MS Dialer.exe and several other Email- and Groupware-clients which are also TAPI compatible.
I verified that with CiscoIOSTSPLite1.3 of Callmanager 3.4 it is possible to use different MS Office Outlook Products and MS Dialer.
