CME 4.0: SIP to SCCP call does not show caller name
I have Cisco 2821 with 12.4.4XC2 and mix of SIP and SCCP phones.
For calls originating in SCCP phone the caller name is displayed on target phone, but for calls, originating on SIP phone, called party does not see the caller name on the dislpay.
This also happens on SIP-to-SIP calls.
Am I doing something wrong?
Thank you.
Relevant config:
ip domain name xxx
voice-card 0
no dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
sip
registrar server
no call service stop
voice register global
mode cme
source-address 172.x.x.160 port 5060
load 7960-7940 P0S3-07-4-00
create profile sync 0052141959334149
voice register dn 7
number 1116
name Petucha
voice register dn 8
number 1115
name Uff Jozo
voice register dn 10
number 1120
name Teofil
voice register pool 41
id mac 0015.DE3D.90CC
type 7940
number 1 dn 10
max registrations 48
codec g711ulaw
voice register pool 42
id mac 0011.3B04.53B9
type 7940
number 1 dn 7
codec g711ulaw
voice register pool 43
id mac 000F.24C6.AC5B
type 7940
number 1 dn 8
codec g711ulaw
controller E1 0/0/0
controller E1 0/0/1
interface GigabitEthernet0/0
ip address 172.24.x.x.255.255.0
duplex auto
speed auto
ip route 0.0.0.0 0.0.x.x.24.34.1
ip http server
no ip http secure-server
tftp-server flash:P0030702T023.bin
tftp-server flash:P0030702T023.loads
tftp-server flash:P0030702T023.sb2
tftp-server flash:P0030702T023.sbn
tftp-server flash:P0S3-07-4-00.bin
tftp-server flash:P0S3-07-4-00.loads
tftp-server flash:P0S3-07-4-00.sb2
control-plane
gateway
timer receive-rtp 1200
sip-ua
telephony-service
no auto-reg-ephone
load 7960-7940 P0030702T023
max-ephones 24
max-dn 24
ip source-address 172.24.34.160 port 2000
service dnis dir-lookup
time-format 24
date-format dd-mm-yy
max-conferences 12 gain -6
moh music-on-hold.au
web admin system name cisco secret xxxx
dn-webedit
time-webedit
transfer-system full-consult
directory last-name-first
create cnf-files version-stamp 7960 Jun 07 2006 21:12:31
ephone-dn 1 dual-line
number 1111
name Fero
call-forward busy 2111
ephone-dn 2
number 1112
name Jozo
ephone-dn 3
number 1113
name HogoFogo
ephone-dn 4
number 3333
name Vsetkym telefonom
paging
ephone-dn 5 dual-line
number 1119
name Uoua
ephone-dn 6 dual-line
number 1118
name Karel
ephone 1
device-security-mode none
username "jano" password jano
mac-address 000F.24A9.6BD6
fastdial 1 1115 name uff
speed-dial 1 1116 label "Micro"
paging-dn 4
button 1:1
ephone 2
mac-address 0002.3F6A.7986
button 1:3
ephone 3
mac-address 0012.7FAE.828D
button 1:2
ephone 5
mac-address 000F.24A9.6F9F
paging-dn 4
button 1:5
ephone 6
mac-address 000F.F704.198E
paging-dn 4
button 1:6
ephone-hunt 1 longest-idle
pilot 2000
list 1133, 1111, 1119
timeout 10, 10, 10
ephone-hunt 2 sequential
pilot 2001
list 1119, 1111
timeout 10, 10
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
ntp clock-period 17179949
ntp server 172.24.34.1
webvpn context Default_context
ssl authenticate verify all
no inservice
end
  • Other Collaboration Voice and Video Subjects
Silver
Re: CME 4.0: SIP to SCCP call does not show caller name
Try a different brand of phone to confirm that the problem is not caused by a malfunctioning or incompatible caller ID telephone. Ensure that the cptone command is set correctly to reflect your local settings.The Following URL also be of help.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca7df.html#1049611
Thank you for your post, but I have only IP phones, so cptone command is N/A. I tried it also with non-Cisco SIP phone and result is the same, so it looks like a problem in IOS or it may be my fault with wrong config...
157
