CME and ATA186
Has anyone successfully configured both ports on an ATA186 attached to CME? I have configured a fax on port 1 and an analogue phone on port 2. Fax works on Port 1 but port 2 doesn't work i.e. no dial-tone when off-hook & can't place/receive a call. I have configured 2 ephone-dns and one ephone as per attached.
ephone-dn 40
number 899
description Fax
name ION Automotive Fax
ephone-dn 41
number 858
description ATA186 Port 2 (Boardroom)
name Boardroom
txt removed
ephone 40
mac-address 000E.38B6.E489
type ata
button 1:40 2:41
Is this correct or do you have to create another ephone as per CCM e.g.remove the leading 00 and add 01 to the end of the address
ephone 40
type ata
button 1:40
ephone 41
mac-address 0E38.B6E4.8901
type ata
button 1:41
  • Other Collaboration Voice and Video Subjects
Blue
Re: CME and ATA186
I just set one up today, and both lines are working.
It automatically created the 2 ephones with the usual mac address relationship. I just added the ephone-dn for each extension, and added the button statements to the ephones.
So, your 2nd example is correct.
I was surprised to find that both lines were able to place G729 calls. With Call Manager 3.3.3 only the 1st line will do compressed voice.
Re: CME and ATA186
Thanks for your reply. Can I ask what version of IOS you are using? I have a 2651XM with 122-15.ZJ3. Apart from not auto configuring, the ATA also would not automatically upgrade the firmware. The ATA came with 215ms and I installed 216ms in router flash. I ended up having to upgrade the ATA manually. I wonder whether it is the IOS version that is the problem. I have attached the relevant config entries here in case I've missed something. Mike.
tftp-server flash:P00303020214.bin
tftp-server flash:ata18x-v2-16-ms-030327b.zup
telephony-service
load 7960-7940 P00303020214
load ATA ata18x-v2-16-ms-030327b
max-ephones 48
max-dn 128
ip source-address 10.36.16.1 port 2000
timeouts interdigit 3
timeouts ringing 10
system message ION Automotive 84565800
create cnf-files version-stamp Jan 01 2002 00:00:00
dialplan-pattern 1 03845658.. extension-length 3 extension-pattern 8..
voicemail 888
mwi sip-server 10.36.16.2 transport tcp
mwi expires 86400
max-conferences 4
moh music-on-hold.au
date-format dd-mm-yy
web admin system name xxxxxxxx
dn-webedit
time-webedit
Blue
Re: CME and ATA186
I am running 12.3(7)T in a 3745,so IOS may very well be the problem. My ATA load is the same 216ms that you have.
Re: CME and ATA186
Do load ATA ata18x-v2-16-ms-030327b.zup
Extension required.
Re: CME and ATA186
The ATA's are capable of handling one G.729 phone call at one time. In many situations, you can configure both ports to do G.729, but if one port is already in a call using G.729 then a second call on the other port will fall back to G.711.
Re: CME and ATA186
One other point. Fax on an ATA is not supported with CCME when connected as a skinny endpoint. There are known issues with this config. Either connect Fax machines directly to router FXS ports, or connect the ATA to CCME via H323. Sarat
Re: CME and ATA186
I know how to load the ATA code on for H323, but do you have to make the gateway a H323 device?
In other words do you have or can you post an example for configuring an ATA as a H323 for faxes? I want to use the ATA's for both voice and fax mixed on the same device.
If I have a setup like this what woould I have to do to get it to work?
AS5400 as the connection to the PSTN
That is connected to a 4500 Series switch
Then the CallManager Express and Unity express ride on a 2621XM router.
Do I have to create a Loopback 0 with and address and then do an h323 bind src address?
I am just curious if the 7912G phones run SCCP and the ATA's have to run H323 because of the faxes can the interoperate on the same box and if so an example would be great.
Thanks so much.
316
