Silver
CME and CCM
I need to call between a CCM cluster to a CME site. I can get it working using gatekeeper for call routing.
Any idea how to get this done without gatekeeper. On CME router, I will create dial-peer pointing to CCM, correct? From CCM, how do I send a call to CME?
Re: CME and CCM
Create the CME as a H.323 gateway in the callmanager. Create a Routepattern for DN's of CME pointing to that gateway.
Re: CME and CCM
Keep in mind that support for a H.323 intercluster trunk is not supported until CME 3.1 within IOS 12.3.7T.
Prior to that Call Manager integration wass not supported, according to everything I have see and heard in docs.
Re: CME and CCM
Right. However, the only thing that would not work correctly is ringback. So, if your users can live without ringback then you should be OK...
-Jaret
112
