CME and Hunt Group
Hello folks,
I am installing a CME with 8 pots lines. There's no DID number here. All incoming calls go to the receptionist with extension 2300. How can I configure a hunt group that If the first line is busy it rings into the second line and if the second line is busy, it rings into the third one and so on?
I also need to make sure that the outgoing calls don't get busy tone. If the first line is busy I need it to hunt to the second and so on. Could you please let me know how can I do that?
Re: CME and Hunt Group
Configure 2300 as a hunt pilot and put individual lines on receptionist phone (2301,2302,2303 etc) as members of the hunt group.
ephone-hunt 1 seq
pilot 2300
list 2301,2302,2303
timeout 10
Sankar
PS: please rate posts!
Thanks Sankar,
This is for incoming calls. Right? Doesn't the Telco (Verizon) do this hunging? How about the outgoing calls. How can I configure a hunt group to make sure that if the first pots line is busy it goes to second and if the second one is busy it goes to the third and so on?
Hall of Fame Super Silver
For you first question you can achive this with couple of methods, first you can create callForwarding on the receiptionist's phone such:
ephone-dn 1
number 1000
call-forward busy 1001
ephone-dn 2
number 1001
call-forward busy 1002
ephone 1
button 1:1 2:2 3:3 4:4 5:5 6:6
or you can create a hunt-list, such as:
ephone-hunt 1 sequiential
pilot 1000
list 1001, 1002, 1003, 1004, 1005, 1006, 1007
timeout 12
For your second question you will need to create POTS dial-peer for every FXO port.
Chris
I have 8 pots lines. Could you please give me an example for the first tow POTS dial-peers configuration and I will copy the same config for all other remaining POTS lines.
dial-peer voice 1 pots
incoming called number .
destination-pattern 1000 (you might need to play with plar commands here)
port 0/0/0
dial-peer voice 2 pots
port 0/0/1
Chris
Thanks Chris, I appreciate your help. Is this for outgoing calls or incoming calls?
Thanks agine,
These dial-peers will be used for incoming calls, for outgoing calls use the following:
dial-peer voice 10 pots
description local calls
destination-pattern 9[2-9]......
preference 0
forward-digits 7
port 0/0/0
dial-peer voice 11 pots
preference 1
forward-digits 7
port 0/0/1
dial-peer voice 20 pots
description long distance calls
destination-pattern 91[2-9].........
preference 0
forward-digits 11
port 0/0/0
dial-peer voice 21 pots
preference 1
forward-digits 11
port 0/0/1
dial-peer voice 30 pots
description international calls
destination-pattern 9011T
preference 0
prefix 011
port 0/0/0
dial-peer voice 31 pots
preference 1
prefix 011
port 0/0/1
dial-peer voice 40 pots
description 911 calls
destination-pattern 911
preference 0
forward-digits 3
port 0/0/0
preference 1
forward-digits 3
port 0/0/1
This gives you an example for 2 of the 8 POTS lines, you have to create local, long distance, international, 911, etc for every FXO trunk.
HTH, please rate helpful posts!
Chris
Hi all,
I am dealing with this same question right now while deploying a VoIP system at one of our remote campuses. I understand you can create a dial-peer for every voice-port and give them incrementing priorities, but this seems very cumbersome (especially in the case where you have 8 pots lines). Isn't there any way to create a hunt group, or trunk group, or something and add the pots lines to the group and then hunt among them? Or is the seperate dial-peer for every voice-port the only solution?
Thanks in advance,
488
