Community Member
CME and remote router IP phone registration.
Can CME support remote router(WAN) IP phone registration along with those IP phones using FXO's connected to that remote router. If so how do I configure the router with CME and the remote router to support this.
Silver
Re: CME and remote router IP phone registration.
Remote phone registration is not currently supported as CME only handles G711 codecs , and most WAN calls would normally be G729. The only way you could use the FXO ports is by configuring VOIP dial peers on the CME router and pointing the calls to the remote remote, using the appropriate codec.
Community Member
Thank you for the response for CME. Looks like what we will provide is CME on the remote routers and dial peers back to the central router running CME also for IP phone to IP phone calling.
186
