CME and strict-match
Does somebody knows what the option "strict-match" at the of the CME Command "ip source-address" does?
Re: CME and strict-match
if a router has multiple interfaces, by default CME allows a phone to register irrespective of which interface the initial request for registration came on.
If you use the strict match command, it will not allow any phones to register unless they have an ip address in the same subnet as that fast ethernet interface and also the request for registration has to come on that particular interface,
Hi Ashok
I also think that, but I had a lab with a CME and a remote IP Communicator. The Ip communicator is able to register even is this command is used.
Alex
Hey Alex, from CCO:
strict-match :Instructs the router to reject IP phone registration attempts if the IP server address used by the phone does not exactly match the source address.
So, it appears that registration will be denied only in the following situation:
router has 1.1.1.1 as fastEthernet 0/0 which is being used as strict match.
It also has another interface, 2.2.2.2 on serial1/1
IP phone requests for registration. However, the request is sent to 2.2.2.2, not 1.1.1.1. With strict match this should fail.
In essense, my statement in the previous post is only half right.
Hi Ashok
But,how an Ip Phone should register to another interface diferent than the command ip source address ?. This ip address is in the XML file that Ip Phones download and is the only one that Ip Phone knows.
Alex
well, you can input another interface as the TFTP address in the phone at:
settings -> 3 -> 8. the strict match will then not let the phone register
316
