CME at remote and CM at HO with intercluster trunks.
can someone share their experience with the above setup.
Brgds
renzil
Re: CME at remote and CM at HO with intercluster trunks.
Take a look at the following article. It gives step-by-step details for this configuration.
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00804ad858.html#wp1001000
Hope this helps.
Brandon
Bronze
Follow the doco that Brandon posted.
Here are a couple of extra things to check for, others may be able to correct some of this but it has been working fine for us.
On the CME apply the 'h323-gateway voip interface' and the 'h323-gateway voip bind srcaddr x.x.x.x' I have these applied on the FastEthernet and replaced the X with same IP.
On the CM it was recommended that should use H323 GW, ensure that the CSS is correct. In my environment when accepting incoming calls since we have a 4 digit extensions I changed the Significant Digits to 4 when accepting incoming calls, this will likely cause issues if the call manager attempts to send it out on PSTN.Check your route pattern.
Hope this works, mine is working thanks to some of the help from this forum.
Heath
115
