CME B-ACD Problem with menu options using param aa-hunt
Experts,
I have set up CME 4.0 with B-ACD for call queueing to a support group. The problem that I am having is I cant seem to get the menu options to call the hunt pilots I have set up. I am using the param aa-huntmenu command and setting the hunt group pilots to match the param aa-huntmenu command. The only options that seem to work are 0 and 1. So if I set up 3 hunt groups and use the command param number-of-hunt-grps 3 and then under the queue service use the same command setting the hunt groups to 3 along with 3 hunt pilots (aa-huntmenu1 - 3) I can press 1 and get to the first hunt group but if I press 2 or 3 then I get an error that is not a valid option. This is the AA and Queue services part of the config
application
service callq flash:app-b-acd-2.1.2.2.tcl
param aa-hunt1 712
param aa-hunt2 713
param aa-hunt3 500
service aa1 flash:app-b-acd-aa-2.1.2.2.tcl
paramspace english index 1
param aa-pilot 710
param handoff-string aa1
paramspace english language en
param call-retry-timer 15
param service-name callq
paramspace english location flash:
param second-greeting-time 10
param max-time-vm-retry 2
param voice-mail 700
param max-time-call-retry 15
The problem is that the menu options when I call in dont work for 2 or 3.
Any info is appreciated.
Silver
Re: CME B-ACD Problem with menu options using param aa-hunt
Configures a call-queue service called queue to associate three menu numbers with three pilot numbers of three ephone hunt groups.Refer URL for configuring hunt group
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_command_reference_chapter09186a008061135e.html#wp1051322
Thanks for the reply. I am aware of how to configure the menu numbers with the pilots using the param aa-hunt command. What I am having problems with is never getting any option but '1' to work. I happened to get it working by doing the following using 2.1.2.2 and 2.0.1.0 B-ACD.
1. copied b-acd 2.0.1.0 to the router
2. no service aa (and) no service queue
3.
application
service queue flash:app-b-acd-2.0.1.0.tcl
param queue-len 10
param aa-hunt1 3601
param aa-hunt2 3602
param queue-manager-debugs 1
param number-of-hunt-grps 2
service aa flash:app-b-acd-aa-2.0.1.0.tcl
paramspace english index 0
param aa-pilot 1000
param second-greeting-time 60
param call-retry-timer 5
param max-time-call-retry 180
param voice-mail 5000
param service-name queue
NOW IT WORKS. I can call in and dial a 1 and get to the hunt group or press 2 and get to the other hunt group.
BUT - I reload the router and when it comes up it doesnt work at all. So I do the following ...
4. no service aa (and) no service queue
5.
application
service queue flash:app-b-acd-2.1.2.2.tcl
param queue-len 10
param aa-hunt1 3601
param aa-hunt2 3602
service aa flash:app-b-acd-aa-2.1.2.2.tcl
param aa-pilot 1000
Now I am back to where I started with menu option 1 working but not menu option 2. So if go back to step 1 and remove the aa and queue services and add them back as 2.0.1.0 then it works until the router is reloaded.
To me it looks like a bug but not really sure....
Craig
335
