CME Call Transfer Limitation
Unable to transfer calls using the local directory; get the following messages (with any CME/IOS version !).
"Handle Current Call" then "Auto dial Cancelled"
I consider this a big limitation in an SMB environment. If a secretary wants to transfer a call using a local directory this is not possible !
Any plans to solve this issue ?
Any workaround or solution ?
Thanks.
Bronze
Re: CME Call Transfer Limitation
I faced a similar issue sometime back but I don't think there is any workaround as of now.
... if somedoby from Cisco is reading this post, pls answer those questions:
- any plans to solve this problem ?
(call transfer using local directory)
- any workaround or solution ?
I've got the same problem, so if anyone from Cisco (or anyone with a workaround) is out there reading this, a fix would be great...
115
