Community Member
CME, dialplan-pattern for direct & redirect case
Two ephones(4001 & 4002) installed in CME and have a question how works the dialplan-pattern for direct and redirect.
telephoney-service
dialplan-pattern 1 111222.... ext 4
-->show telephony-service dial-peer
dial-p v 20001
destination pattern 4001$
dial-p v 20002
destination pattern 1112224001$
choose dial-peer 20001 when I direct dial "4001" and 20002 when call-forward to 4001 from 4002.
Is the e164 expantion via dialplan-pattern only applicable call-forward?
Thanks in advance,
Bronze
Re: CME, dialplan-pattern for direct & redirect case
Yes, It's only applicable to call forward
Silver
To add to that, here are a few more uses of dialplan pattern as per the Command reference manual
1. A dial-plan pattern is required to register the Cisco IP phone lines with a gatekeeper.
2. The pattern created by the dialplan-pattern command is also used to enable distinctive ringing for inbound calls. If a calling-party number matches a dial-plan pattern, the call is considered an internal call and has a distinctive ring that identifies the call as internal. Any call with a calling-party number that does not match a dial-plan pattern is considered an external call and has a distinctive ring that is different from the internal ringing.
Check this link for details
http://www.cisco.com/univercd/cc/td/doc/product/voice/its/cme33/cme33sa/cme33phn.htm#wp2261346
Anup
359
