CME on 28XX registration problem with GK
I have central GK on 7200 and remote CME bracnh routers. Earlier they were on 1760, and I had issue of preventing local DN's registering with central GK.
With forum reply from anup.anand, I was able to do it by configuring :
ephone-dn 10
no register primary.
So it was working well.
Now I am trying to deploy CME on 2811 routers but the same "no register" command under e-hone-dn doesn't prevent registering it with the central GK.
Is there any other workaround to do this ?
1 REPLY
Silver
Re: CME on 28XX registration problem with GK
That is strange.
Try using this command in the gatekeeper to clear the registration, just in case if the ephone got registered before you added the no register and due to some reason it didn't clear itself.
clear h323 gatekeeper endpoint
If that doesn't help, then as a workaround you can use the "no zone subnet" command in the gatekeeper to force the gatekeeper to not accept any registration request from the 2811. Be advised that this will affect all registrations from the 2811, not just the ephones. So if you have any FXS/FXO ports, then those numbers won't get registered either.
Anup
107
