CME SIP Trunk Help
Hello
I have SCCP IP Phones connected to a CME Router, and want to pass calls to a SIP Service Provider. I have setup a SIP Trunk which works, but the problem is that I can only specify one username in the sip-ua config, so I can on get one phone to make calls.
Is there a way I can get multiple phones to work, and keep then on SCCP.
1 REPLY
Re: CME SIP Trunk Help
You should only need one username. The SIP trunk provider can allow multiple calls over a single trunk.
Hope this helps.
Brandon
202
