CME/SRST to test PRI and calls for new turnup in and out.
Can someone give me a simple CME config to test a new PRI at a site with one phone? The WAN that will connect to our call manager will be going in after the voice circuit and I'd at least like to test calls inbound and outbound if possible with CME. The router will be a Cisco 2851 running IOS 12.4.4(XC2) Advanced IP services. In production the router will be the SRST gateway.
Not sure if you can test it with SRST if it never talked to CM before...
Thanks.
  • Other Collaboration Voice and Video Subjects
1 REPLY
Re: CME/SRST to test PRI and calls for new turnup in and out.
You cannot test it with SRST as the phone needs to talk to CM once. So you can use CME.
here is a sample config.
isdn switch-type primary-ni <--replace with yours
controller t1 0/0/0
pri-group timeslots 1-24
framing esf
linecode b8zs
clock source line primary
telephony-service
ip source-address 192.168.10.1 port 2000
max-dn 2
max-ephones 1
create cnf-files
load 7960-7940
tftp-server flash:
ephone-dn 1 dual-line
number 2000
ephone 1
mac-address
button 1:1
int s0/0/0:23
isdn incoming-voice voice
dial-peer voice 1 pots
destination-pattern 9T
port 0/0/0:23
incoming called-number .
Notes: You may have to give a card type command if its a vwic2-mft card which may be t1 or e1 or using a nm-hdv2. Also you will need to extract cme 4.0 basic files (downloadable from CCO) and atleast put the 7960/7940 phone load (or the load for which ever phone you are using) so that the phone will be able to boot up and register with CME.
Sankar
PS: please remember to rate posts!
404
