Community Member
CME to Broadsoft SIP trunkgroup outbound calls
This is my dial-peer for outbound calls over SIP trunk. Does not work. Number not found - any ideas?
dial-peer voice 1 voip
translation-profile outgoing PSTN_Outgoing
huntstop
destination-pattern .T
voice-class codec 1
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
Anonymous
N/A
Re: CME to Broadsoft SIP trunkgroup outbound calls
What is the error message you are getting?
Community Member
your SIP provider may only provide G711ulaw audio, as mine does. If so, the above configuration will not work by itself, as voip dial-peers use g729r8, by default. add the following command under the dial-peer:
codec g711ulaw
199
