Hall of Fame Super Silver
CME to CCM Consult Transfer issues
I have customer that is having issues with consult transfers, basically the transfer works for blind transfers, but not for consult.
Snippet of the CME config:
telephony-service
load 7960-7940 P00303020214
max-ephones 40
max-dn 135
ip source-address 192.168.x.x port 2000
timeouts interdigit 3
create cnf-files version-stamp 7960 Aug 22 2005 14:40:19
voicemail 480
max-conferences 8
call-forward pattern .T
moh music-on-hold.au
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
transfer-pattern ...
secondary-dialtone 9
Chris
1 REPLY
Hall of Fame Super Red
Re: CME to CCM Consult Transfer issues
Hi Chris,
Is it possible that the ephone-dn has transfer-mode blind set on it which overrides the system setting?
transfer-mode {blind | consult}
Example:
Router(config-ephone-dn)# transfer-mode blind
(Optional) Specifies the type of call transfer for an individual ephone-dn that uses the ITU-T H.450.2 standard, allowing you to override the global setting.
•blind—Transfers calls without consultation using a single phone line.
•consult—Transfers calls with consultation using a second phone line, if available.
From this doc:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00805abb82.html#wp1071598
Hope this helps!
Rob
Please remember to rate helpful posts......
117
