CME transcoding issues
I have two 2811 routers running CME version 3.4. I can’t get transcoding to work between the two CME routers. When I call the Unity Express pilot number on CME router 2 from CME router 1, I get a fast busy. If I set the dial-peer to use G.711, it works fine. Below is the transcoding related configuration from the two routers. Any help you can give me would be much appreciated.
CMR router 1:
voice-card 0
no dspfarm
dsp services dspfarm
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
codec g729r8
codec g729br8
maximum sessions 12
associate application SCCP
telephony-service
load 7960-7940 P00307020200
load 7914 S00104000100
load 7905 CP7905060000SCCP050124A
load 7936 cmterm_7936.3-3-5-0
load 7912 CP7912060000SCCP050124A
max-ephones 20
max-dn 100
ip source-address 10.10.1.250 port 2000
sdspfarm units 1
sdspfarm transcode sessions 16
sdspfarm tag 1 mac0015.f98e.01
CME router 2:
voice-card 0
no dspfarm
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
codec g729r8
codec g729br8
maximum sessions 12
telephony-service
max-ephones 20
max-dn 100
ip source-address 10.10.2.250 port 2000
sdspfarm units 1
sdspfarm tag 1 mac0015.fa2f.75
I have just added the following commands to my configuration:
sccp local FastEthernet 0/0.2
sccp ccm 10.10.1.250 identifier 1
sccp
sccp ccm group 1
When I do a “show sccp all”, I see the following:
Transcoding Operational State: Down – Cause Code: NOT_ACCOC_TO_CCM_GROUP
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED, Profile Indentifier:1
In my running configuration I have the following sccp related commands:
sccp
sccp ccm group 1
associate ccm 1 priority 1
10.10.1.250 is the IP address for CME on this router. Fast Ethernet 0/0.2 is the sub-interface the above address is assigned to.
What is causing the Transcoding Operational State to be Down?
Thank you for all of your help!
Chris
Anonymous
N/A
Re: CME transcoding issues
Check for the DSP resources available, may be you can use DSP resource calculator.
http://www.cisco.com/pcgi-bin/Support/DSP/dsp-calc.pl
debug dspfarm events,
http://www.cisco.com/en/US/products/hw/routers/ps221/prod_configuration_guide09186a0080106d1c.html
Silver
Try adding these commands
sccp ccm group 1
associate profile 1 register mtp
** use the mac address of fastethernet 0/0.2
telephony-service
sdspfarm tag 1 mtp
Check this link for more information.
http://www.cisco.com/univercd/cc/td/doc/product/voice/its/cme33/cme33sa/cme33trn.htm
regards,
Anup
167
