CME translation-rule help
I am running cme 3.1. I am trying to translate a dialed number of 0 into 1001. 1001 is the extension of the operator. My translation rule is as follows:
translation-rule 1
Rule 0 0 1001
When i run a test translation-rule 1 0 i get the following output:
The replaced number: 1001
So it looks like it should be working.
Can anyone shead some light on this for me?
Frank
1 ACCEPTED SOLUTION
Silver
Re: CME translation-rule help
Yes the translation rule is correct. You need to make sure that you apply it to the correct voice-port or ephone-dn.
ephone-dn 1
number 1005
translate called 1
1 REPLY
Silver
ephone-dn 1
number 1005
translate called 1
225
