Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CMM module and conferencing
does anyone know if you can used the DSP's on an un-used T1 port of the 6-T1 module for conferencing (simillar to how the 6608 works) or do you have to use the ACT module?
Blue
Re: CMM module and conferencing
you need the ACT module to be able to define transcoding/conferencing resources on the CMM.
please see the following link for more info:
http://www.cisco.com/en/US/products/hw/modules/ps3115/products_data_sheet09186a00800e9c1f.html
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/prod_bulletin09186a00801c400a.html
Bronze
James:
You have to use the ACT. We tried to get one going without, but could not access the DSPs (using CCM4.1(3)sr3c and a CAT6513). It appears the hardware transcoding takes place on the ACT module itself for conference resources.
Hope that helps.
Tom
Thanks for the reply. To bad....not quite as flexible as the 6608.
118
