CMM Module
I have a CMM modoule running 12.x.x. I can ping the GIGabit Ethernet IP address but I am getting ping packet loss when I ping the fast Ethernet IP address in the CMM module.
Is the fast E on the CMM supposed to b e pingable cause it has a /32 subnet mask (accdg to Cisco).
I dont have issues pinging the Gigabit Ethernet.
I have 1 6port T1 and 1 Conf Module on the CMM. Conferencing works fine.
Just trying to figure out if pinging fast E is supposed to work...
Green
Re: CMM Module
It should be pingeable since RTP stream is mix there and audio actually is sourced from that interface.
Make sure FE is configured in the proper VLAN.
Bronze
Re: CMM Module
Paul
On my CMM I can ping both.
My configuration is similiar to yours, 1 6-port T1 module and 1 Conference Module.
Larry
Re: CMM Module
Thanks. My ping works but not all the time. I tried to reload using the hw-module command and seem to fix it for now...I'll keep you posted...
119
