Codec for iPAQ to play Voicemail
Does anyone know if there is a codec available to be able to listen to the Unity voice mail on the iPAQ w/ Pocket PC 2002 and Windows Media Player<br><br>
1 REPLY
Anonymous
N/A
Re: Codec for iPAQ to play Voicemail
Try GSM 6.10, some folks out here have reported success with that on various hand held devices. You can set this using the SetRecordFormat utility under \commserver\utilities.
Jeff Lindborg
Unity Technical Lead/Answer Monkey
Cisco Systems
lindborg@cisco.com
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
99
