codec payload for IP Phone
Can the payload of the codec on an IP Phone changed like it can on an H.323 gateway. If not what is the impact of a gateway with a 40 byte g729 codec rather than the standard 20 byte payload?
Re: codec payload for IP Phone
Yes You can.
Do next - login to CCM server.
After that go Service->Service Parameters.
Select a CCM server.
At the left side You will see Services, select "Cisco CallManager" Service.
You are at the Service Parameters Configuration Menu.
Go down to the next parameters:
PreferredG711MillisecondPacketSize
PreferredG723MillisecondPacketSize
PreferredG729MillisecondPacketSize
Change them as You wish.
Thanks, I'll give it a try.
123
