Compatibility between CCM 3.12c and CCM 3.32
I have a CCM cluster running 3.12c. I want to bring up a new cluster running 3.32. Will I be able to create InterCluster Trunks between the clusters while they are running different CCM release levels?
AND Will the phones in the 2 clusters be able to communicate between clusters?
Larry
  • Other Collaboration Voice and Video Subjects
Blue
Re: Compatibility between CCM 3.12c and CCM 3.32
There will be no issue's with this. However, you may want to look through the bug list for any issues with inter-cluster trunks and CM 3.12, if I recall CM had issues at that point with them.
Hi Larry,
I had previously done an InterCluster trunking between 3.1.3a & 3.3.2 CM cluster. It worked well.
But do take note the difference in configuring intercluster trunking for CM 3.1 & 3.3.
89
