Conference Bridge Issue on 2651XM
We are trying to setup a 2651XM with NM-HDV-FARM-C90 module running 12.2(15)T2 IOS. We have configured the 2651 for uses as a DSP farm only, no transcoding, and configured the bridge in CM(3.1.4b SPD).
Althought we can add the 2651as an IOS conf bridge, under CM the brdige does not show as registered nor does it display its IP Address. THe 2651 is on the same subnet as the CM and I can ping CM from 2651 and the 2651 from CM.
When attempting a conference call, the first called party gets put on hold and it allows me to dial the second called party. But as soon as I hit conf softkey to bring all 3 parties together all calls are cleared down.
Any suggestions
David
1 ACCEPTED SOLUTION
Re: Conference Bridge Issue on 2651XM
David,
Per http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080110bc5.html#1072534,
Cisco CallManager 3.2(2c) or a later version is required.
Michael.
David,
Michael.
Many thanks. Looks like a 3.3 upgrade is called for sooner than we expected.
David.
97
