Conference with another site via Frame relay (WAN) .
We can't use conference function over WAN link (Frame/Relay). Does i need transcoder H/W to relay
communication session bentween two sites.
Intranet G.711 / Extranet G.729
Re: Conference with another site via Frame relay (WAN) .
If you are using the software conference bridge, then this will not work.
If you use a hardware conference bridge such as those available for the Cat4k or Cat6k chassis, then the hardware conference bridge will be able to conference callers with different codec types and mix the audio together.
Should we need transcoder h/w each site or just one?
Thanks a lot .
145
