Conferencing and Transcoding resources on 1760v
Hey guys,
Does the 1760v support the ability to provide CM with Transcoding and Conferencing resources. Like the VG200 and MRP-300 in the ICS.
Craig
1 REPLY
Re: Conferencing and Transcoding resources on 1760v
I don't think so, but the 2600's and 3600's do. See this:
http://cisco.com/en/US/partner/products/hw/routers/ps259/products_data_sheet09186a008010fba0.html
If you check out the Software Advisor you can see if you can download a version of IOS for the 1760 that also supports conferencing, which is a feature you can specify in the Advisor.. That might be a better indication.
http://www.cisco.com/cgi-bin/Support/CompNav/Index.pl
Brandon
123
