Configuration example for 7970 running 8.0(2) SIP Firmware
Does anyone have an example configuration or reference for the SEP<mac>.cnf.xml file for a 7970 using the new SIP firmware? I've looked everywhere but can't find *anything*.
Silver
Re: Configuration example for 7970 running 8.0(2) SIP Firmware
You will typically need be concerned with only 3 files, OS79XX.TXT, SIPDefault.cnf, and
*.bin. You must have these 3 at least in the root directory of your tftp server
(Example) To upgrade to sip version 7.3.
1) make sure that the OS79XX.TXT contains only the filename P0S3-07-3-00
2) make sure that the SIPDefault.cnf contains P0S3-07-3-00 in the image_version field
3)make sure phone has the correct ip address of the TFTP server
4)remove/reattach power from phone for it to go through the correct upgrade procedure (do
not use reset sequence). The phone will powercycle itself after a successful upgrade).
check these link for more information on upgrade procedures.
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_example09186a00805a2fa5.shtml
http://www.cisco.com/en/US/products/sw/voicesw/ps4967/products_upgrade_guides09186a008022a968.html#wp1053742
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_example09186a008042326b.shtml
I too would be most interested. I am testing out a 7941 with SIP, which also requires a SEP.cnf.xml file. Unfortunately as it's not yet running in a CM environment I can't generate one to see quite what it would look like and get it to become "provisioned".
Documentation on this format is basically non-existant it seems, however the older 7940s with their older style non-xml format *are* well documented.
701
