Configure 2801 for 15 channel PRI
I'm new to configuring PRI's so excuse me if there is an obvious answer to my question. I recently purchased CUCM Business Edition and a 2801 router. I've configured the CM and the router and now have outbound calling working but cannot call in to any of the DID's. On the controller I did
pri-group timeslots 1-15 service mgcp
and i want to know if anyone knows if that is correct for a 15 channel partial PRI. Also if anyone has any ideas why I'd be able to make calls out but not receive calls. Any help greatly appreciated.
Here is part of the router config:
controller T1 0/1/0
framing esf
linecode b8zs
pri-group timeslots 1-15,24 service mgcp
interface FastEthernet0/0
ip address 172.16.6.1 255.255.255.0
speed 100
full-duplex
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface Serial0/1/0:23
no ip address
isdn switch-type primary-4ess
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip classless
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
disable-eadi
voice-port 0/1/0:23
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 172.16.6.2
ccm-manager config
mgcp
mgcp call-agent 172.16.6.2 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp profile default
line con 0
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Configure 2801 for 15 channel PRI
the ISDN is all good. The problem is that your CM doesn't know what to with called number 16619.
Unfortunately I'm not good with the CM configuration to tell you exactly how to translate this number to match your extensions.
If you were using H.323 or SIP, it would be instead a simple configuration on the GW.
Hi Houstonrob,
You do not have the DID configured, that's why you cannot receive calls. Your voice gateway receives the call through the PRI but do not know what to do with it.
configure:
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
Hope this helps if so please rate below in the checkbox.
Justin
Justin,
He is using MGCP, consequently DP do not apply.
Still, it would be needed to see a "debug isdn q931" with "term mon" to understand the problme.
Thanks for the help, when i do debug isdn q931 or 921 there is no activity until i try to call one of my numbers, then i get:
2801VGW#debug isdn q931
debug isdn q931 is ON.
2801VGW#
*Jul 4 14:18:59.229: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0A92
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Called Party Number i = 0x80, '16619'
Plan:Unknown, Type:Unknown
*Jul 4 14:18:59.233: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref =
0x8A92
Cause i = 0x8081 - Unallocated/unassigned number
and
2801VGW#debug isdn q921
debug isdn q921 is ON.
2801VGW#
*Jul 4 14:21:03.089: ISDN Se0/1/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=6 n
r=6
*Jul 4 14:21:03.093: ISDN Se0/1/0:23 Q921: User TX -> RR sapi=0 tei=0 nr=7
*Jul 4 14:21:03.097: ISDN Se0/1/0:23 Q921: User TX -> INFO sapi=0 tei=0, ns=6 n
r=7
*Jul 4 14:21:03.105: ISDN Se0/1/0:23 Q921: User RX <- RR sapi=0 tei=0 nr=7
Thank you very much, you pointed out that the telco setup for 5 significant digits, they shouldve set up for 4. I'll call them and have them correct the problem
You're welcome, thanks for the appreciation and good luck!
460
