Configure Softkeys for 7960 SIP?
derekagar
Is there any way to configure the softkeys for a 7960 using SIP? I would like to put a DND button on.
Derek
7 Replies 7
CME / CUCM?
Neither, Switchvox.
I have a linux box setup with tftp/dhcp/dns for the phone network.
I have SIPDefault.cnf and then also a corresponding SIP.cnf which has specifics for the phone. I have not found any documentation anywhere on how to change the softkeys with the SIP firmware.
Derek
Based on the lack of response, I am going to assume the answer is no.
Hi Derek,
This is something you can do.
In the .cnf.xml file the phone downloads, add/edit this field:
softkeyDefault.xml
Here's the default from my SIP CME system, attached.
hth,
nick
I was unaware that the latest sip firmware for 7960 used xml files. I have a SIPDefault.cnf and a SIP.cnf
Are you able to attach the .cnf.xml files?
Also, are you able to put in the DND sotkey? I am wanting to have the dnd button displayed.
Hi Derek,
I'm not sure about this. They are probably similar. This was from a Cisco 3951 SIP phone, but I imagine it's fairly similar.
I don't currently have a 7940/60 set up in the lab to test with.
-nick
