Configuring a NM-HDV-2E1 for E1 R2
I've to configure a NM-HDV-2E1 with E1 R2 signalling on a cisco 3640 router.
Before, I've already configured a Patton Access server, and all have worked properly. I want to reproduce the same config on the cisco but I couldn't find the correcponding parameters.
Here the working parameters on the Patton access server :
Line Signalling :
Country: custom(2)
Idle Code: abcd-1001(9)
Forward Seize: abcd-0001(1)
Back Acknowledge: abcd-1101(13)
Back Answer: abcd-0101(5)
Minimum Transition Time (ms): 400
Minimum Detection Time (ms): 0
Protocol Timeout (ms): 130000
Can anyone tell me what's the corresponding config on the cisco router, because i've searched on the online docs for this detailed config and I've not found anything about.
Thanks in advance.
Fethi.
P.S. My country is Algeria, if it helps !
1 REPLY
Silver
Re: Configuring a NM-HDV-2E1 for E1 R2
Hi Fethi,
I don't know if Algeria has a custom version of R2, but if they use ITU defaults the following should work -
controller e1 0/0
ds0-group 0 timeslots 1-31 type r2-digital r2-compelled
voice-port 0/0:0
cptone FR
compand-type a-law
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
port 0/0:0
Have a look here for more information on configuring and customising R2 -
http://www.cisco.com/warp/public/788/signalling/e1_r2_sig.html
http://www.cisco.com/warp/public/788/signalling/e1r2config.html
http://www.cisco.com/warp/public/788/signalling/e1_r2_cas_custom.html
228
