Configuring Controller E1
Hi,I want to connect my router with my PABX using a controller E1. The card I have in the PABX is a TLU76/1. I need to know how to configure my router? I'm using CCME.
I appreciate your help
regars
Leo
Silver
Re: Configuring Controller E1
I don't think there is a difference in configuring an E1 Controller on CME to an ordinary voice router. Here is a standard E1 config:
isdn switch-type - "specify what type you are using"
controller E1 2/0
framing - "specify framing type (crc4 etc)"
pri-group timeslots - " specify timeslots"
!interface Serial2/0:15
isdn switch-type - "specify type again"
voice-port 2/0:15 -
Please check this document describing interoperability between the Ericsson MD110 PABX and a Cisco router.
http://www.cisco.com/application/pdf/en/us/guest/products/ps278/c1237/ccmigration_09186a00800e6e6c.pdf
Additional guides for Ericsson PABXs can be found here:
http://www.cisco.com/en/US/products/hw/routers/ps259/prod_troubleshooting_guide09186a0080142535.html
Regards.
188
