configuring DSP for conference
i am having the hardest time configuring DSP services on my 2801.
i going ena - conf t - voice-card 0 - dsp services dspfarm - then this happens 2801(config-voicecard)#dsp services dspfarm
% Invalid input detected at '^' marker.
i know sccp is enabled.
i know there is nothing wrong with the router or DSP's.
i've been using this document as a guide
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/vvfax_c/callc_c/ccm_c/intcnf2.htm#wp103251
thanks in advance.
  • Other Collaboration Voice and Video Subjects
Re: configuring DSP for conference
Do you have any other voice ports installed in the router? How many dsps do you have?
i added a pvdm module when the 2801 came out of the box. on my other routers only the voice-card 0 is configured.
Jerry - Cisco has a useful tool called the DSP calculator located at http://www.cisco.com/cgi-bin/Support/DSP/cisco_prodsel.pl
Plug in your router specifics and it will provide you with the correct configuration command lines to get your conferencing up and running.
Jerry,
Try applying the following command I had a simular problem last week. "network-clock-participate wic 0"
Hope this helps.
my router didnt like it.
config)#network-clock-participate wic 0
WIC slot is empty or does not support clock participate
Bronze
Is that IPVOICE IOS loaded in your 2801?
Use "sh diag" to make sure the router recongize the PVDM module u install.
Ken
i needed to upgrade the IOS to 12.3 (11) just like the documents says.
Is that IPVOICE IOS loaded in your 2801? no its "spservices".
whats the difference?
Bronze
IP Voice IOS has better handle about voice related command, module, etc.
If you can try to load IPVOICE IOS, see if solove your problem.
Ken
132
