Community Member
configuring DTMF tones
I have to configure DTMF in dial peer voip but I don't know which type have to configure rtp-nte or cisco-rtp.
What's the difference both them?
Thank you.
Regards,Paolo
Green
Re: configuring DTMF tones
It will depend on your setup-
For CCM we use dtmf-relay h245-alphanumeric
since CCM only understand this type of DTMF as inbound.
For SIP we use Named Telephony Events (NTE), or RFC 2833 which is dtmf-relay rtp-nte
The cisco-rtp Forwards DTMF tones by using Real-Time Transport Protocol (RTP) with a Cisco proprietary payload type.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087edb.html#24720
Community Member
thank you for your answer but I forget to tell you that I'm using CCME on Cisco 1760-V.
Is there difference with CCM configuration?
Regards, Paolo
137
