Configuring E1 voice circuit in Mexico. Using MGCP
Just installed 3845 with E1 voice circuit (VWIC2-1MFT-T1/E1) in Mexico. Using a single cluster centralized design. We have got a problem to pass calls to and from my telephone service provider. The e1 is registered in CCM as a voice gateway using MGCP.
We were told the E1 voice circuit detail as below.
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line
If someone has been successfully configured E1 with MGCP Mexico, appreciate can show us a list of parameters for this type of gateway setup (3845 with VWIC2-1MFT-T1/E1 running MGCP) in CCM.
Thanks in advance.
Wilber Jimenez
Mexico
Green
Re: Configuring E1 voice circuit in Mexico. Using MGCP
Hello Wilber,
I have worked with mexican customers and normally they use E1 R2 for either Telmex or Telnor.
Since u r using E1 with MGCP let me know the PSTN protocol u r using to interface with your Telco (Telmex,Avantel, Axtel whatever)
If you are using E1 R2, H323 is a must.
//G
Hello
Thanks for answer.
i am using E1 R2 modified and my telco is telmex.
Here are the commands used
controller E1 4/0
framing NO-CRC4
line-termination 75-ohm
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled
cas-custom 0
country telmex
category 2
answer-signal group-b 1
In the CCM do i need some special configuration?
Why do i need h323, is not possible with MGCP?
Thanks a lot
Wilber
Green
Because MGCP is not capable to translate E1R2 states from GW to CCM, like it does with ET1PRI|T1CAS|FXO|FXS
The RFC 2705 doesnt have yet a definition for R2.
Actually H323 do support call preservation now.
Is this still not supported
Is this still not supported or is there any workaround using MGCP now?
749
