06-02-2003 12:17 PM - edited 03-13-2019 12:09 AM
Has anyone actually configured the Automatic Selection (GetIP.asp) for the Network Audio Settings on the IP Softphone. Docs are lacking regarding this configuration. Any insight would be helpful...thanks.
06-02-2003 01:34 PM
Yes, it works very well, install on the ccm server, you also need to install the distribution client on the server as well, some minor tweeking during the install if you do not want to install the distrubution client, and config your softphone client to use getip.asp, and poof, bring up your vpn, launch sf, your off and running.
06-02-2003 01:43 PM
Do you have the documentation to install it? Are you talking about the Softphoen software on the call manager. Can you explain the procedure in little bit detail.
thanks
06-02-2003 04:20 PM
06-02-2003 04:34 PM
Perfect! Thanks!
