Configuring ISDN PRI to ATT NSF Megacom
Has anyone configured a isdn pri to a ATT NSF megacom to support call by call. This is a first for me. Inbound calling is fine, outbound calling drops because calls are not being tagged. Any help would be great.
1 REPLY
Silver
Re: Configuring ISDN PRI to ATT NSF Megacom
Have you configured dialer map class for the outgoing calls. With the command : "dialer voice-call {map-classname}" configured and then " isdn nsf-service" interface configuration command, you should be able to make outgoing calls successfully. Try "dialer outgoing" map class command also. I do not know the results. But it seems to be similar.
To know more about all these commands refer to :
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_command_summary_chapter09186a00800ed403.html#5400
678
