10-23-2006 09:07 AM - edited 03-13-2019 03:29 PM
Currently we run a single Publisher and Subscriber, with all phones obtaining Information, Directories, and Services URL's from our Subscriber server. Is there a way to setup the Publisher so it can be a backup server for these services if the Subscriber server is offiline?
10-23-2006 11:17 AM
There is currently no way in CCM to achieve this type of redundancy. One option is to use round robin DNS to simulate redundancy.
Brandon
11-09-2006 10:22 AM
Same concept, different DNS feature. We use CNAME records and can push changes to the DNS server. This requires that you have a relatively short lifetime on DNS auth. responses.
Another approach, if you have the equipment, is to use a load balancer solution.
You could also offload your web services (to a certain extent) to other dedicated web hosts that may have redundancy options built into the solution.
Or, a mixture of all of these which is how we deal with things.
01-23-2007 01:59 PM
I know when entering the URL for the service, you can use the variable #DEVICENAME# for the phone's device name. Wonder if there's a variable you can use for the active CallManager...
