Configuring Siemens IP Phones with Cisco and Nortel Switches
Guys our company is implementing VOIP and they are using Siemens phones
Just a run down on our network the core switch is passport the distributions switches are Baystack 5520 and the edge switches where ip phones are plugging in are Cisco 3560.
Please find below the configuration of the cisco switch.
interface FastEthernet0/4
switchport access vlan 5
switchport mode trunk
switchport voice vlan 25
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 5 (Data)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: 25 (Voice)
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Switch#sh int f0/4 trunk
Port Mode Encapsulation Status Native vlan
Fa0/4 on 802.1q trunking 1
Port Vlans allowed on trunk
Fa0/4 1-4094
Port Vlans allowed and active in management domain
Fa0/4 1,5,25
Port Vlans in spanning tree forwarding state and not pruned
Fa0/4 1,5,25
The phone is getting the right ip address and which is 10.0.160.0. The problem is with the Pcs plugged back into the phones. They are getting the ip addresses in the range of 10.0.140.0 and which is our default vlan vlan 1. As seen from the above the data vlan is 5 and the pcs should get ip address from that vlan which is 10.0.150.0. Any suggestions / ideas ?
Tks
Harmander
1 REPLY
Re: Configuring Siemens IP Phones with Cisco and Nortel Switches
Harmander,
I am not sure that this is the best setup but you could try: "switchport trunk native vlan 5"
I don't think you would need "switchport access vlan 5"
V.
1104
