Configuring VIC2-4FXO with POTS Lines in India
Does anybody know if there is anything special with POTS line in India ?
I trying to bring up a 1760v voice gateway with a VIC2-4FXO connecting 4 analog lines in India and it seems like I am not getting any type of connectivity from telco. I have tested each analog line with an analog phone and they're all working fine. But I am not able to get them to work when connected to the 1760v router, I am confident that the router config is fine, I have done this before just not in India. I am just not sure if there is anything special with the analog lines in India.
Thanks in advance !!!
Danny
Re: Configuring VIC2-4FXO with POTS Lines in India
Danny,
What happens when you call inbound ?
Can you paste your configs, as well as "sh voice port summary" output
Default signalling for FXO is loopstart so you may want to change it to ground start and see if that helps. Also to help match up the Tones and cadences you may want to see if cptone command under fxo is set to "cptone in".
Sankar.
Hello Sankar ! thanks for your response. When I call inbound the call just keeps ringing and I don't see any activities on "sh voice port summary". I have tried change the signal to GroundStart but didn't help, also have tried "cptone in" too and didn't help either. I have attached the config of the router.
Thanks Sankar !!
Danny
144
