Community Member
Connect Cisco Call Manager to AVAYA Definity G3R
Anybody know how can i connect an AVAYA Definity G3R to an Cisco Call Manager vía a Cisco VG200.
Thank in advance.
Community Member
Re: Connect Cisco Call Manager to AVAYA Definity G3R
get an NM-HDV-1T1-24= or 2T1-48
have AVAYA give you T1 trunk (wink)
this is from a production VG200------Avaya G3 connection
and do something like this
controller T1 1/0
framing esf
linecode b8zs
ds0-group 0 timeslots 1-24 type e&m-wink-start
controller T1 1/1
framing sf
linecode ami
interface FastEthernet0/0
ip address
duplex auto
speed auto
ip classless
ip route
no ip http server
voice-port 1/0:0
dial-peer voice 1 pots
destination-pattern .......
port 1/0:0
dial-peer voice 2 pots
destination-pattern 7...
port 1/0:0
prefix 7
dial-peer voice 3300 pots
destination-pattern 3...
port 1/0:0
prefix 3
dial-peer voice 4400 pots
destination-pattern 4...
port 1/0:0
prefix 4
dial-peer voice 111 voip
destination-pattern 6...
session target ipv4:
dtmf-relay h245-alphanumeric
codec g711ulaw
there are few other ways to do it.
Community Member
There are many ways to connect to the Definity. It all Depends on What you are try to accomplish.
Do you want a T1 connection?
Do you want Call ID to work?
We have done many connections to our Definity G3 Via a VG-200.
You can send me an email and I will send you some Documentation on how to set both the Call Manger Side and the Definity Side.
There is also some good Docs on the CIsco Side the you can look at.
Here is the link to them
even though the Information is for a 3600 router the set up is the same.
Good Luck
