Connect to routers with HWIC-1ADSL
I couldn't find whether this module can be used as a central site DSL device(the client function is sure). This is needed to directly connect to Cisco router equipped with HWIC-1ADSL modules. I was using by now two Zyxel modems, but there is a difference between the two models (one of them is especially specified as a cetral side modem).
I will appreciate any answer!
1 REPLY
Hall of Fame Super Gold
Re: Connect to routers with HWIC-1ADSL
No, it is not possible to do so.
If you want back-to-back connections over dry pair, use HWIC-4SHDSL:
www.cisco.com/en/US/prod/collateral/modules/ps5949/ps7175/prod_qas0900aecd80591ff1.html
134
