Community Member
Connected number display - inbound
Any incoming call results in our five-digit internal number being displayed to the caller. Outbound calling (phone mask and name) is all good. We don't have any translation patterns affecting what is sent out on to the PSTN. Have tried different combinations of all the PRI protocol options - but nothing seems to be having an affect.
Green
Re: Connected number display - inbound
*Mar 1 01:46:02.047: ISDN Se1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x00F7
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x2183, '7809535722'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '51662'
Plan:ISDN, Type:Subscriber(local)
*Mar 1 01:46:02.123: ISDN Se1/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x80F7
*Mar 1 01:46:02.123: ISDN Se1/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x80F7
*Mar 1 01:46:02.123: ISDN Se1/0:23 Q931: TX -> NOTIFY pd = 8 callref = 0x80F7
Connected Address i = 0x80, '51662'
Notification Ind i = 0xF1
As you see we are sending the NOTIFY message
Thats why caller got the as connected number the internal extension.
You are hitting this DDTS:
CSCdv84167 - When CM receives an inbound call and sends CONNECT message when call has been answered, we send Display IE in the message if the Display IE checkbox is enabled for that gateway.
We need to add another checkbox called "Connected Address IE Delivery" or something appropriate. When enabled, this will cause CM to send the
Connected Address IE in the outbound CONNECT message.
//G
Community Member
Have unselected the "Display IE" but seemed to have no affect. Will reload gateway, instead of just resetting, to see if it makes a difference. DN level has internal name, alerting name, line number and mask on all the phones, whether a DID or non-DID. We have tried both direct numbers (51662) and redirected numbers (51600 to 53000 to 59004) - and we are consistently sending out, when it is an incoming call, the five-digit.
Green
Check this parameters also at DN level
Line Settings for all Devices
Alerting Name
Line Settings for this Device
Display (Internal Caller ID)
Community Member
I'm a novice when it comes to CCM, but why wouldn't CCM send the external phone number mask in a case like this? We're about to implement Cisco IPT and I'm worried that we'll run into the same problem since we have several PRI circuits.
174
