vk
Connecting 6608 E1 to Dialogic D/600JCT-2E1
I have tried to connect 6608 E1 to Dialogic D/600JCT-2E1 using CCM 3.1(1) with 6506 MGCP Gateway with no luck - always get red light and status "notconnect"
Can anyone tell me how the Gateway Configuration page in the CCM should look like ?
Thanks in advance,
Vidir
Re: Connecting 6608 E1 to Dialogic D/600JCT-2E1
I have never connected to a card like that but I would suspect that you would need a E1 crossover cable to get this to work. Did you use a straight through cable or a crossover?
Thank you,
-Mckee
vk
Hi Mckee and thanks for your reply.
I have tried to use both cat5 crossover and straight cables without luck - always red light and the 'notconnect' status.
thanks,
Vidir
128
