connecting an pbx with multiple bri-lines to an cisco3660 with viv 2bri S/T
hello,
i have connected an pbx with 4 isdn lines to an c3660 (ios 12.2.13T) with 2 2bri s/t nt interfaces. in addition the c3660 has one e1 interface to the pstn. so i will have 4 voice ports for the connection to the pbx. i have bound my dial-peers referring to the pbx to all my bri voice ports.
in the beginning all was working fine. but now, when an phone behind the pstn wnts to start an external call, the phone gets an busy signal. when i do an debug isdn q931 on the router i see that there are all b-channels busy. but when i do an show isdn stat the router tells me that there
are free b-channels.
could someone tell me whats wrong here? i have searched the bug navigator for this topic but i didn´t find anything.
1 REPLY
Re: connecting an pbx with multiple bri-lines to an cisco3660 wi
here i added the configuration of the gateway :
isdn switch-type basic-net3
voice service voip
modem passthrough nse codec g711alaw
ccm-manager music-on-hold
mta receive maximum-recipients 0
controller E1 1/0
pri-group timeslots 1-31
translation-rule 1
Rule 0 ^0 999
translation-rule 2
Rule 0 999 0
interface FastEthernet0/0
ip address 192.168.90.252 255.255.255.0
ip pim version 1
ip pim sparse-mode
speed 100
full-duplex
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.90.252
interface Serial1/0:15
no ip address
no logging event link-status
isdn switch-type primary-net5
isdn overlap-receiving T302 5000
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
interface BRI2/0
description **** 1. Verb. zu TK-Anlage ****
no ip address
isdn protocol-emulate network
isdn point-to-point-setup
isdn layer1-emulate network
isdn sending-complete
isdn static-tei 0
isdn skipsend-idverify
interface BRI2/1
description **** 2. Verb. zu TK-Anlage ****
no ip address
isdn static-tei 0
interface BRI3/0
description **** 3. Verb. zu TK-Anlage ****
no ip address
isdn static-tei 0
interface BRI3/1
description **** 4. Verb. zu TK-Anlage ****
no ip address
isdn static-tei 0
interface BRI4/0
description **** S0 Amtsanschluss ****
no ip address
isdn overlap-receiving T302 7500
interface BRI4/1
description **** zu TK-Anlage ****
no ip address
router ospf 1
log-adjacency-changes
area 0 authentication
network 192.168.90.252 0.0.0.0 area 0
ip classless
ip http server
ip pim rp-address 192.168.90.252
call rsvp-sync
voice-port 1/0:15
translate called 1
cptone DE
voice-port 2/0/0
compand-type a-law
cptone DE
voice-port 2/0/1
compand-type a-law
cptone DE
voice-port 3/0/0
compand-type a-law
cptone DE
voice-port 3/0/1
compand-type a-law
cptone DE
voice-port 4/0/0
compand-type a-law
cptone DE
voice-port 4/0/1
compand-type a-law
cptone DE
mgcp profile default
dial-peer cor custom
dial-peer voice 100 pots
description **** dial-peer fuer Amtszugang ****
destination-pattern 0T
direct-inward-dial
port 1/0:15
dial-peer voice 200 pots
description **** dial-peer zu TK-Anlage ****
destination-pattern 999
no digit-strip
direct-inward-dial
port 2/0/0
dial-peer voice 205 pots
preference 1
no digit-strip
direct-inward-dial
port 2/0/1
dial-peer voice 210 pots
preference 2
no digit-strip
direct-inward-dial
port 3/0/0
dial-peer voice 215 pots
preference 3
no digit-strip
direct-inward-dial
port 3/0/1
dial-peer voice 220 pots
description **** 1. dial-peer zu TK-Anlage ****
destination-pattern [1-7].
no digit-strip
direct-inward-dial
port 2/0/0
dial-peer voice 225 pots
preference 1
no digit-strip
direct-inward-dial
port 2/0/1
dial-peer voice 230 pots
preference 2
no digit-strip
direct-inward-dial
port 3/0/0
dial-peer voice 235 pots
preference 3
no digit-strip
direct-inward-dial
port 3/0/1
dial-peer voice 240 pots
destination-pattern [8-9]..
no digit-strip
direct-inward-dial
port 2/0/0
dial-peer voice 245 pots
preference 1
no digit-strip
direct-inward-dial
port 2/0/1
dial-peer voice 250 pots
preference 2
no digit-strip
direct-inward-dial
port 3/0/0
dial-peer voice 255 pots
preference 3
no digit-strip
direct-inward-dial
port 3/0/1
dial-peer voice 300 pots
destination-pattern 5909[3-5]
no digit-strip
direct-inward-dial
port 4/0/1
forward-digits all
119
