Connecting CME 4.0 to Voice Gateway
knightr
I have a 2600XM running CME 4.0 and a 1760 with 2 FX0 and 1 FXS card. Both routers are running IOS 10.4(9)T. I would like the 1760 to act as a gateway using H.323. Can anyone advise me on how to set this up?
8 Replies 8
thisisshanky
Level 11
Level 11
So you are running CME on the 2600 and you want to send h323 calls to 1760 ? PSTN calls, internal calls, are they in teh same lan or are they across a wan circuit ?
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
oh sorry, over the PSTN via FXO ports
in the same LAN
DIal-peers pots and voip
to send calls from ccme to fxo
on ccme - voip dial-peer to remote ip add
on remote rtr- pots to the associated ports
on 2600
dial-peer voice 1 voip
dtmf-relay h245-alpha
codec g711ulaw
no vad
destination-pattern 9T
ip qos dscp cs3 signalling
On 1760
codec g711ulaw
no vad
incoming-called-number 9T
dial-peer voice 1 pots
port 1/0 ---- fxs port
Sankar
PS: please remember to rate posts!
Sankar Nair
Sankar,
Thanks for the quick response. I will give this a try, but I'm confused as to how the CME router will know to forwards call to the voice gateway router for outgoing calls and vice versa for incoming calls without some IP addresses being involved.
Ray
Thanks for the response. I will give this a try.
I forgot to put the session target commands in there. The configs i posted will work only for outbound calls. I will get you the inbound configs here soon.
In the 2600, under dial-peer voice 1 add the following command
"session target " .
Sankar Nair
